Old 06-26-2002, 07:27 AM
hermco hermco is offline
Default Re: question for FELLOWSHIP And OTHER members
Make sure the area is dry,freshly sanded and wiped down with acetone before you begin the repair.I once saw a guy do a spot for Ship Shape TV about repairing areas that have no access from the inside of the boat.He used a piece of cardboard with the glass wet out and a wire thru the middle.He then folded the cardboard pushed it thru the hole and used the wire to pull it down to the inside of the hull.When cured you cut the wire, sand and begin the build up of glass from the outside.Pretty neat trick.
d.h. [img]images/icons/wink.gif[/img]
