Another method you may want to try and use for heating up a rubrail is soaking it in hot water for a few hours. It makes it very pliable and easy to work with.
To do this....My buddy rigged up a big plastic drum with a heating element from a hot water heater. He turns it on and lets the rubrail soak in it (covered up) for a few hours until it is very pliable. |
You know what they say, 3's a charm!! [img]images/icons/tongue.gif[/img] [img]images/icons/tongue.gif[/img] [img]images/icons/tongue.gif[/img]
Capt. Brian |
LOL @ Capt.
Pat
Worry less, Fish more! |
Definitely go with the Taco stainless. Use a heat gun to form the hard vinyl, but DO NOT overheat or you'll be adding a lot of joints to your rail or buying new vinyl. Be patient.
I have a 1976 SeaCraft 18, never plan to get rid of it. Just in the process of completing a major overhaul from a bare hull / adding new transom. A lot of work, but it will be nice when done. I'll post a picture -- once I figure out how! |
The easiest way to install a flexible rubber rail is to find the center of the new rubrail and place a screw thru it at the bow,then pull the rail tight over the top of the deck to the aft corner of the boat and install a screw.Then strech the rail into position and fasten with screws approx every 8".It works for me!
d.h. [img]images/icons/smile.gif[/img] |
