Old 01-30-2003, 11:45 AM
SECF3114M73J SECF3114M73J is offline
Default Re: stringers
Thanks for the info,I'm gonna mount to the deck and try to avoid the stringers. It may be hard to do if the stringers are 3" wide.The leaning post will be 38" wide,haven't seen it yet but would guess the feet are no more than 36" wide. A freind is rebuilding the transom on his '78 23' C.C., his port stringer was completly detached from the transom and the stbd. stringer was partially detached. The stringers at the trans. are about 1.5" thick.He sistered 3'4 ply wood on both sides of the stringers and glassed everything over and tabbed to transom,it's solid as a rock.He also removed the live well and raised the transom to 30". So far it looks real nice, glass work is done, now he's gonna re gel coat.
Old 01-31-2003, 01:42 AM
Briguy Briguy is offline
SECF, What did your buddy do with the old livewell?? Did he simply seal it up or did he take out the old motorwell and add deck space? As for your leaning post question. I have a leaning post and just screwed it into the deck with 4200 and it's like a rock.
Capt. Brian
Old 01-31-2003, 01:49 AM
Bri, he cut out the livewell and raised the deck of the motor well,glassed over the access panels, and installed one of those round access hatches to get at the motor mounting bolts,etc.The bulkhead between the well and the cockpit was not modified..
