Old 03-06-2003, 02:31 AM
OTTERLY COOL OTTERLY COOL is offline
Default Re: 23' rebuild progress
OTTO
It's me again
Yeah! Where are the Stringers - the potters had fiberglass (no wood at all) box stringers that were filled with foam and went flat to the deck. They were sort of inverted, flat bottm "U"'s that were glassed to the bottom of the boat so that the flat portion of the "U" met, and probably supported the deck. In fact, my 1984 20 - (it wasn't a 1988 as I stated before on the site-that's when I traded it in. It was a CSY or something boat- I don't think it was a tracker yet) had the box stringers also - they went flush to the deck as far as I could see ( when I went "inside" to replace bilge pump)and they were filled with some kind of expandable foam. I know that to be true because they (CSY ??) never covered the expansion holes - I covered the holes with mat and epoxy because I was afraid the foam would eventually become saturated. (Sorry -kind of rambling tonight).
What am I missing in your pictures - or was I wrong about the stringers all these years.
Let me know.
KEEP WORKING
BOB
RWM
Old 03-06-2003, 03:12 AM
SECF3114M73J SECF3114M73J is offline
Stringers? In the interior pictures the vertcal surfaces you see are the stringers(except for the transom). The stringers take a 90 degree turn and narrow down a few feet forward of the transom. I don't know for sure, but I think they are layed out to accomodate a V8 I/O engine. The I/O and O/B 23's have the same stringer layout.
[ March 06, 2003, 02:15 AM: Message edited by: SECF3114M73J ]
Old 03-06-2003, 10:13 AM
saltydog saltydog is offline
Otter,
After being in this bilge and boat for the better part of a month fulltime, I have become pretty familiar with it's structure. The stringers run aft and terminate with a 90 degree at the end of the fuel compartment. Under the deck there is a second set of stringers that run from just short of the transom forward. The two are connected at the 90 mark with a side to side 2 foot stringer. I think that Otto posted some pics before we put the new floor in that show that second set of stringers. This other set of stringers is extremely helpful in giving the sole, out towards the hullsides, support. These as you all know were filled with foam. There are two weep holes at the end of the fuel compartment stringers were the ply base meets the stringer. when we took out the tank we had to remove the bulkhead at the end of the tank. This was glassed in over the weep holes in the stringer. These need to be open. After removal we noticed moisture coming from this area. When we looked further we noticed that they were holes and proceeded to open them up. With that out came the water that had been holed up in there. As we thawed out the boat more moisture was released. Again, these holes need to be open. They were cut out but glassed over trapping the water inside. The water diversion channels on each side of the tank were also cut off with glass by the bulkhead, again trapping water, now in the fuel compartment. You will see whan Otto posts the pics of the new bulkhead that we have cleared the channels and allowed for a much larger flow area.
Old 03-07-2003, 01:48 AM
Eric McNiff Eric McNiff is offline
That is going to be one sweet ride when you get finished.....nothing like knowing the important stuff was done right when you are staring down the 8ft. seas. I just bought a '77 and will probably do the same thing next year....going to try and get one year out of her first. Looks great!
Eric
My wife does not care for the 2 boat theory
Old 03-06-2003, 11:26 PM
ocuyler ocuyler is offline
The "shop" we are using has plastic on 2 sides and a 250K "salamander" for heat. Loud and smelly and cold quick when it turned off. We have been having trouble getting the MAS epoxy to harden as nights are in the teens and twenties every (freakin) night.
So we decided to move it into the real shop with heat and insulation and lights and everything. We removed the door, hinges and one side of the jam to get exactly the 97" needed the boat is wide at midships. Touching concrete to gel coat ever so slightly on each side. Here are images of it's new cramped but cozy 70 degree 24/7 home:
We were conserned with (and warned about) the MAS epoxy not curing fully before painting. She's smiling now. So is Tom...
Oh, yea, check out the 2-1/8" diameter hole in the bottom of the transom that Tom installed a couple of days ago. Nice job!
Otto
[ March 06, 2003, 10:30 PM: Message edited by: Otto Cuyler ]
Otto
Old 03-06-2003, 11:42 PM
Looks good ..Just don't forget..!.!.! Don't put the rub rail back on before you take her back outside, sounds like she may not fit if you do.... [img]images/icons/shocked.gif[/img] C
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
