Old 03-16-2003, 09:23 PM
rudders_midship rudders_midship is offline
Default Re: gas tank
How bad is you " surface corrosion" [img]images/icons/confused.gif[/img] if its pitted at all it is junk its called crevice corrosion and it is caused by trapped water against the aluminun,Most likey using scotch brite or light sanding will reveal more extensive damage,caused by foaming in a tank, now days is a no no other methods are prefered today. Aluminun tanks are fairly inexpensive Im having one built right now. A gas leak is something that could ruin your whole summer [img]images/icons/shocked.gif[/img] I dont belive epoxy is the answer this time [img]images/icons/smile.gif[/img]
1978 20' SeaCraft Sceptre 2003 25"115 V-4 Johnson
JAM
