Old 04-02-2003, 10:19 AM
Default Re: inside or outside
YOU CAN START ANY TIME YOU LIKE FROM TACKY TO HARD BUT RUFF SAND IF IT HARDENS. I USED A SHEET OF 1/8 “ WOOD WALL BOARD ATTACHED IT TO THE OUTSIDE OF THE HULL WITH CLAMPS TOOK A PENCIL AND TRACED THE BOTTOM OF THE HULL DESIGN ON THE WOOD CUT IT OUT (INSIDE THE LINES) AND IT FIT PRETTY GOOD I THEN GROUND IT TO EXACTLY FIT. AFTER THAT YOU CAN TRACE THE NOTCH IF YOU ARE NOT GOING TO INSTALL A BRACKET BUT WAIT UNTIL YOU GET YOUR BOTTOM FITTING CORRECTLY FIRST BEFORE YOU CUT IT OUT.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
