Old 04-02-2003, 08:36 AM
EP EP is offline
Default Re: T-top reconditioning
I used an aluminum color but they have many colors that you can chose from. Easy to come by too as it is ussually in any Rust Oleam display. I believe I used 3/8 as mine overhang over the frame of the top 5 inches all around. Your top is quite a but larger but as long as it ends at the framework I would use 1/4. (the stuff isn't cheap) I believe their was a good supplier posted for it not so long ago. I routered the edges and the stuff was easy to work with. Good Luck and I assure you that you it will be awesome looking.
