Old 08-12-2003, 04:42 PM
Doug Erickson Doug Erickson is offline
Default Re: Leak
Bet Al Rigoli would know
Old 08-12-2003, 06:26 PM
Ed Ed is offline
Default Re: Leak
NJ fisherman-
I would first try removing and then reseating each thru hull with 5200. Then, if your boat is still leaking....move on to the deck drains and replace or reroute them as necessary. By doing it systematically, you'll be able to isolate the problem.
Good luck.
Old 08-12-2003, 06:39 PM
BARNABY55 BARNABY55 is offline
Default Re: Leak
believe it or not, I found water coming thru the bow eye. you might check that
Ted
Old 08-13-2003, 11:53 AM
Brian Rice Brian Rice is offline
Default Re: Leak
Ed I have one through hull and it is visible and brand new and dry. I wish it was that though.
Barnaby how low is your bow eye? Mine is way above the water line so I know it isn't that.
Thanks guys I will keep plugging along here.
[ August 13, 2003, 10:53 AM: Message edited by: NJfishman ]
Old 08-13-2003, 12:12 PM
Default Re: Leak
Is the boat in the water all of the time? When do you see the water, once the boat has been sitting for a few days? or is it dry then you run it and then see water.. I had a problem were the bilge would be dry(trailer days)I'd put the plug in launch the boat. Take off and the next time I set the boat down the bilge pump would come on.. Pump it out. and it would happen twice every trip then stop. Problem was, when I would wash the boat(every trip)water was getting into the side compartments and laying on the outside stringer in the low point of the hull(no limber hole in the stringers).When I would bring hte boat on plan the water would run aft and into the bilge center section. drove me nuts till I figured out what it was. Added limber hole and solved the problem
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 08-13-2003, 12:15 PM
Billybob Billybob is offline
Default Re: Leak
Just a thought, but when you checked your outdrive did you do it with the drive tilted up? Sometimes those cracks in the bellows are real small and hard to find.I saw one that didn't leak when it was down, but did when tilted up.Maybe just something to double check.
Bill
Old 08-14-2003, 10:26 AM
Default Re: Leak
Boat is on a lift the water is salt so it has to be coming in somewhere. The bellows is brand new it seems to only be leeking when the boat is at rest. I am thinking that it is the deck drains.
Thanks
