Old 01-22-2004, 11:09 AM
ScottM ScottM is offline
Dieter Sprockets
Default Re: I have a little problem?!?
I just spoke to Jason and it sounds like you're all set with the pics. He sent them to me - boy what a mess! SC better stand behind their product and fix this at no charge to you. Good luck and keep us posted.
Old 01-22-2004, 11:27 AM
Trayder Trayder is offline
Velvet Jones
Sorry about the delay-
Looks pretty serious also looks like wate can pour in from the gap into the hull?? I wish you luck.
Old 01-22-2004, 11:54 AM
Well a picture is worth more that 1000 works on this one. If this was my boat I would look at this as a serious problem not just a cosmetic one as I thought on my previous post. For me I would pull motors and have transom re done. There is a reason that you have all these cracks “just painting over rotten wood” thinking is not the way to go on this one. You have a separation or de lamination of the fiberglass resin from the composet material used plus that entire transom got to be full of water. The good news “I HOPE” is that this is a 1999 hull and should have a hull warrantee that should pay for the work. I just tried to check on the warrantee but could not find it on their web site. If SeaCraft doesn’t want to pay for the repair I would go to a boat survey company to confirm the amount of damage that is there and then put the heat on SeaCraft to do the right thing.
FellowShip [img]/images/graemlins/mad.gif[/img] [img]/images/graemlins/frown.gif[/img]
Old 01-22-2004, 12:58 PM
Captn C Captn C is offline
The hull still has 8 months on the warranty.
I'm not sure I want a new/rebuilt boat. I don't know what that would do to my re-sell value?!?
I would prefer a new hull. When the boat was first bought they (Bass Pro Shop) installed all the electroics and placed the Furuno thru hull directly in front of the starboard engine. I had didn't pay attention to that fact, but noticed the lower water pressure on my pressure gauge. They said the water pressure on that engine was fine. But when I took it to another shop they seen it and told me the transducer (a big boat shaped) disrupting the water flow DUH! So I want that issue addressed as well.
Women love me, fish fear me!
Team C Craft
Old 01-22-2004, 01:08 PM
gbf03 gbf03 is offline
Capt. C
A few years ago I cracked my hull on my 1995 17 Mako,so I called up mako and ask to have an adjuster come out and take a look at it. He did and said that it was my fault. I fought it to the end, until they agreed to give me a new hull. It took a couple of months but they did. What they did is they took my old hull stripped it and put all the old stuff on the new boat. One thing they did that I didnt like is that I asked them not to bottom paint it and they did. They tittled the boat a 1995 even though they replaced the hull in 2001. Alls that it takes is a little fighting and persistance and you will get what you want.
George
20 SEACRAFT SF / 29 SEA VEE
F.S.U. / REEL SWEET FISHING TEAMS
Old 01-22-2004, 01:46 PM
Thanks for the info George.
I hope; with SeaCraft and Mako both being owned by Bass Pro Shop their polices about hull replacment would about the same.
The Asst. Manager has aready said he went over the boat and couln't find any thing that would make him beleive it was damaged during use. They replaced (BPS Houston) the hull on a 32' SeaCraft when I was buying mine, he had hit something. The boat had a hair line crack in the gell coat along the center line under the boat and some kind of impact mark. They repaired the hull and he came back a month or so later cracked again. So they replaced his hull.
I hope to be so lucky!
Team C Craft
Old 01-22-2004, 01:49 PM
Whoops! [img]/images/graemlins/blush.gif[/img]
Thanks for posting my photos. My mom taught me better manners than that! Sorry
Team C Craft
Old 01-29-2004, 06:13 PM
GetReel GetReel is offline
I've been following this and heres my two cents: Document everything and confirm everything in writing. If you don't get satisfactory results immediatly, get tough. Your pictures indicate faulty workmanship and defective materials. I'd insist on new boat or take the money and hire a first class shop to fix it right, unless that will void the warranty, which leads me back to insist on a new boat or cash back...good luck and give'em hell.
Old 01-29-2004, 07:50 PM
Ed Ed is offline
I see this stuff all the time on newer Makos...which are made in the same factory by the same people.
Document everything and keep in constant contact with the dealer and the Seacraft rep. Also, you should hire a lawyer...someone with marine experience.
With that said, I don't think $14,000 is unreasonably high to fix the exterior cracks and the major interior crack. A lot more work than most of you think.....plus, the boat absolutely has to look as good as new, or the manufacturer won't pay the repair guy.
If I were a betting man, I would think you will probably get a new hull. If you dont, get the existing one fixed and then you may want to think about selling it.
Ed
Old 02-03-2004, 03:40 PM
I'm not sure I want the liability of selling something that I don't feel is safe.
I posted about my boat on The Hull Truth and got referred back to this site, this thread. So it doesn't look like they have had this problem before.
Not sure if that is good or bad??????
Team C Craft
