Old 12-24-2004, 06:52 PM
SEAFARI SEAFARI is offline
Default Re: Suzuki 225 4 Stroke
They use those new 16" dia. Props. A 16x20 is
a good starting point with that gear ratio.
Keep us posted on performance numbers when
she's broken in.
Rodney
Old 12-25-2004, 06:02 PM
corbinj43 corbinj43 is offline
Thanks for the suggestion. Really looking forward to seeing how this engine will do. Replacing a 97 200 Rude. Should see a big difference in fuel flow at least. Will post performance and fuel flows when I get them.
Old 12-27-2004, 07:29 PM
ocuyler ocuyler is offline
jlc,
Are you at all conserned about the 100 pound difference in weight between your old and new? Your thoughts please.
Otto
Old 12-27-2004, 11:05 PM
Otto,
Yes I am concerned about the weight!!! My Armstrong bracket has 450 lbs of floation I heard, but my old 200 rude rides pretty low in the water. I sure hope I have not opened up a big problem. I won't sell the old motor until I know for sure. I got way to good a deal on the Suzuki not to buy it.
Old 12-31-2004, 05:01 PM
Dunk Dunk is offline
Another thing is Suzuki's prop pitch's are not comparable to the real world pitches. The 16" props may be different, but their V6 14-15" props are about 3" high. A 14.25 x 20" Suzuki prop will run exactly the same RPM's as a 17" Stiletto or any other brand's 17" pitch.. If the dealer is suppling that 16 x 20" wheel make you test it with the load you normally carry before you let them walk away from it.
Old 12-31-2004, 11:40 PM
warthog5 warthog5 is offline
Any idea's why that is Dunk? If you were picking an aftermarket prop, would you go with the Stiletto's as opposed to another brand?
