Old 04-05-2005, 12:05 PM
dcobbett dcobbett is offline
Default Re: Tools
Thanks for all the input. To be more clear in my question, when I used the term grinder, I was thinking of grinding fiberglass, not metal.
Old 04-05-2005, 05:09 PM
Scott Scott is offline
Default Re: Tools
The "metal" grinders have an accessory attachment the uses "sandpaper" disks and a flexible backing plate .... Removes fiberglass quite rapidly!! 36 and 50 grit chew through stuff REAL fast and WAY WAY too fast to use as a buffer 10k rpm
sanding disks kits for grinders
I have the “buffer” as Big shrimpin mentions the 9227 … and have the sanding disks for that also but the smaller Makita works better for glass removal IMO
I also have one of these …a DA sander / polisher. Another good sander although I go through sandpaper quick with this one. I use this more after the rough grinding is done
Porter Cable
