Old 04-24-2005, 08:34 AM
Scott Scott is offline
Default Re: Buffing & waxing questions
Paul
I have done what Vezo has detailed out.
I would also suggest getting (if you dont already have one) a real good buffer. It will make your work come out nicer and will finish up faster...like the one that has been mentioned here before ... Makita 9227 is what I have, well worth the cost as its a strong polisher. I'm sure there are many others to choose from.
Another suggestion... you may want to try two products by WoodyWax. They have a spray on carnuba wax and another product called Ultra Gloss. The Ultra gloss has a polishing compound in it IN addition to a wax. I put some on an area of the hull that was pretty heavily oxidized. I buffed it out by hand and was really surprised by the result. I then used the spray carnuba. It sat out with southern exposure from last September and it still looks great. The folks at WoodyWax said with a machine it would come out even better(again my test area was all done by hand).
I have used all those products that Vezo has used with exception to the Starbrite step over the carnuba. Vezo ... Is that what you meant when you said many will disagree?? Truthfully it sounds like it would only help to further protect.
Again ... The WoodyWax products worked great for me. I will use the buffer to see how that affects the final finish. WoodyWax has a website which will give you more info.
Old 04-24-2005, 09:01 AM
Ed Ed is offline
Blizzard-
Vezo gave you some good advice. My only suggestion would be use to 3M's gelcoat polishing compound (which is white and more aggresive) over 3M's heavy duty rubbing compound (which is red and is meant for paint).
I also use the Starbrite Teflon polish with very good results.
Ed
Old 04-24-2005, 09:53 AM
ocuyler ocuyler is offline
Ditto above comments. I use a wool pad for compounding and a foam pad for wax and sealer.
My best tip for buffing is to work in areas of 36" wide so you can stand in one spot and work the buffer back and forth. I apply compound to the hull with a brush and wax with a damp pad, never putting either directly on the wool or foam pads.
Practice makes perfect...
Otto
Old 04-24-2005, 11:40 AM
Michael Vezzosi Michael Vezzosi is offline
Scott, how are ya? No, where I meant that disagreement would surface would be Blizzards choice of wax. Many would not agree that an auto finish will give results as well as something designed specifically for gel/glass, and I may have to agree. However, this system works (very well) for me. A lot of work, but I only have a 20!
Ed, I did not specify that I used the white compound. Thank you. Also, 3M rep. showed me something new. It also was white, called 3M Imperial. I think it would fall in between the Heavy Compound (white) and the Finesse-It. Received sample but have not tried yet.
And Otto, was hoping you were going to say hello while in town. Wanted your opinion on my MA, and thought you might check out the refurb on the 15 Whaler. Right in the middle if addressing all of this now. Mahogoney finishing out much nicer than even I had anticipated. Part I says "Screw it." Dunk it". He did 8 coats to his 18 SC but did not last 2 seasons. Unfortunately he does not live OVER his boathouse! Get home safe. Vezo.
Old 04-24-2005, 03:32 PM
abl1111 abl1111 is offline
3M 'white compound' wheeled on in small areas. Then, Collonite's Heavy Duty airplane/marine wax - paste, not the liquid... 2x w/ the wax by hand...
Old 05-03-2005, 07:29 AM
Sleeto Sleeto is offline
Hey guys thanks for the great advice. I used my heavy duty automotive buffer with 3M Heavy Duty and then Finesse. What a great shine - the hull looks brand new!! I used a wool pad for the Heavy Duty and a foam pad for the Finesse.
Now for the wax. Lord only knows what I'll use. Talking about wax is like talking politics. I'll probably just keep it to myself.
Thanks again!!!
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
