Old 07-01-2005, 11:03 PM
warthog5 warthog5 is offline
Default Re: Some recent up grades
Ahhhhhh! Working in the shade in Ca. Look's good Doc.
I'm not getting crap done. To damn hot here and I need an extra hand.
Old 07-02-2005, 03:10 AM
Thanks guys...the sturgeon are abundant around here however they can be elusive and finicky on the bite. We use eel, grass shrimp, Herring, and pile worms to name a few. The meat is good if prepped right. Must be cut thin and seasoned and it kinda tasts like chicken. No bones in the fish. I'd come to help if I were closer Bobby. Have a great 4th of July fellas.
Old 07-03-2005, 04:11 PM
laser laser is offline
Hey strick...boat looks great
Can you explain your livewell connections? I'm getting ready to do mine...above deck, under the seat and I want to be able to pump it out into my fish tank.
Bill
23, Potter bracket, twin 135 rudes
Old 07-04-2005, 12:43 AM
The two port's comming out of the livewell allow you to change the amount of water in the livewell. 1/2 full or total full.
Just turn that Y valve to do so.
Depending on the bait you have, you may not need or want it totally full. Especially if your down to the last live bait chasing it around the tank.
I belive that's a 27gal Kodiak.
Old 07-04-2005, 01:40 PM
Hey strick...boat looks great. Can you explain your livewell connections? I'm getting ready to do mine...above deck, under the seat and I want to be able to pump it out into my fish tank.
Bill I'm not sure what you mean by "pump it into your fish tank". My live well drain's overboard via two thru hulls.
My tank is a 27 gallon kodiac. The business end has three fittings in the middle of the tank. The top and middle fittings are for the over flow drain. The black valve (the one Bobbby talked about)allows you to adjust the water level in the tank. The bottom middle fitting is to drain the tank at the end of the day. The thru hull for the bait tank overflow is on my port side and is even with the level of the bait tank if it were half full. The thru hull for the bait tank drain is on the starboard side and is about even with the floor of the boat. The fitting on the bottom right of the bait tank is were the water pumps into to fill the tank. I have seacocks on all the thru hulls. E mail me if you have more questions.
Some pics:
Bait tank business end:
Bait tank as it sits on the deck:
Bait tank pump. Also feeds water to the washdown pump not shown in pic.
Seacock for tank drain.
Seacock for tank overflow.
Level of thru hull for tank overflow
Level of thru hull for tank drain.
