Old 08-03-2005, 10:41 AM
warthog5 warthog5 is offline
Default Re: re the SeaBird - oh yeah -
Well, I gott'a ask.
oldbluesplayer, Why did you just cut the center of the core out? Rather than do a "Complete" transom rebuild.
IMHO You have set up two more point's that could result in a sheering motion, unstead of moving the forces all the way out to the side's of the boat.
You were already 80% there and fell short.
Old 08-03-2005, 11:53 AM
Default Re: another transom job in the works -
Ha Worthog
Thanks for asking that question I thought the same thing but did not have the chance to post your question.
Ha Old Blues Player
I have to admit that I totally agree with your comments regarding the west system epoxy. I could never have done my boat all alone with out any help by using polyester resen. When I did my boat the first project I did was to laminate a layer of glass on the gas tank plywood deck in the shade here in South Florida after that “should have been easy project” I knew I needed more time that polyester would give me. If I can remember correctly I used 12 gallons of epoxy to do everything needed and don’t regret that decision as all.
FellowShip [img]/images/graemlins/grin.gif[/img]
Old 08-03-2005, 02:44 PM
Default Good questions - some thoughts/ answers
Scott - my brother has a place in Oak Bluffs, back up by the water tower, Bad Boy is kept on a trailer at his friends, who is the owner of the Admiral BenBow Inn, down by OB harbor... by derby I assume you mean the striper/bluefish derby in sept ? We were there last year, expect to be there weekends again this year.
Fellowship - used to do the surfboard thing outside - shaping the foam is wicked dusty, and counted on a hard 10 minute clock on the polyester resin, from first hardener to useless - beginning to gel, in the summer in New England. Sure can't be any easier in Florida !
Warthog - You got the real question, which really bugged me as I started into this. I've been an engineer too long, so I analyzed the heck out of this, and every example I could find in the back pages and photo albums...
accumulated thoughts
finished strength will be a combination of bonded surface area and mechanical capture, both of transom and bracing structure - the inner well is a significant strengthening member, some of the inner well cuts I've seen worry me about weaking of the supporting structure
IMHO - look at TimD's pictures of a 20 rebuild - I would worry having taken the cutout that close to the edge of the transom, would really have to wrap the rebuild around the corner - tricky job, it appears that his CC had a double motor wide cutout, less side wing surface bond area, really needed to go full width, and evidently his wood was all shot
alot of the examples are on 23's, with a double wide motor cutaway, again, less surface area to bond to
closest to mine appeared to be Hammer's 20, same size boat, same transom shape with single motor cutaway - he appears to have done about the same shape cut out, plus, as I intend, he did a glass wrap from the inner transom / splash well, over the transom edge, and on to the outer face of the transom - excellant mechanical capture, plus it seals the one probably worst seam on the boat, preventing a reoccurance of water getting in to the new transom, and strongly reinforces the structure, between the primary structure, the transom, and the secondary supporting structure, the inner cap/splash well assembly - IMHO that inner cap/splashwell piece significantly supports the transom.
most everybodies pix showed a live well port on the port side of the motorwell, mine had a buried hole thru the core, on the starboard side, glassed over on the inside, glassed over on the outside skin, but a 4" hole thru the plywood core -
This feature alone completely fooled me - as it was directly below the Teleflex mounting holes, leading me to believe the core was disintegrated rotten.
I set the circular saw to 1/4" depth, and cut off the skin in the shape as seen, and aside from being wet in the motorwell/ motor mount hole areas, my plywood was intact.
If I thought plywood could adequately dry out, I might well have left it in place, but I know it can't adequately, in reasonable time, dry across the ply boundaries. Wet, up here in New Hampshire, even salt water will freeze in the winter, and the wet wood would eventually turn to mush from freezing and thawing.
I was initially prepared to have to cut more off, go all the way out to the edge, leaving a 3" rim, if need be, but I had good wood where I stopped.
Wow - this is Way Too Long - give you an idea about how much I researched and thought about this.
- I've got all good wood now
- I reinforced the inner transom
- I kept my supporting structure intact
- I'm going to tie the transom to the existing supporting structure, the splashell assembly, with a transom wrap
- I'm going to add a knee brace, supporting the transom to the hull floor/ keel stringer
- I'm being as careful as I can with all the surface prep work
and I'm gonna hope this works - and believe from all your previous efforts, that one can successfully cut holes in boats, and rebuild them satisfactorily !!!!
Bill
Old 08-03-2005, 03:21 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Good questions - some thoughts/ answers
Bill,
Yup, the striped bass/bluefish derby. We stay at a house up behind the Oceanview Restaurant on Laurel Ave. I'll be down there Sept 10-18 so maybe we can hook up some time?
Old 08-03-2005, 03:59 PM
Default Scott -
cool - I'll probably be down there several weekends in Sept - we launch the Bad Boy on the town ramp over in the lagoon by Vineyardhaven - definitely have to hook up -
right now I'm estimating one more weekend, good weather permitting, to finish my boat up, then give it a trial splash in a local lake, then a more serious shakedown up in Winnpesaukee, so's I can chase some salmon while I'm at it... and swim to shore if it falls apart... - and then hopefully get out to the coast for some blues - and if everything looks good, tow it to Falmouth and bop over to the Vineyard sometime during the derby.
Bill
Old 08-03-2005, 04:20 PM
Default transom loads - Warthog -
looking further, I think I know where you are coming from, that most of the motor force forward thrust load is carried by the transom at the edges, into the hull - kind of similar, in reverse, to the transom test people talk about, standing on the tilted motor to see if the transom flexes under the weight -
both views are expecting that the transom is an unsupported, or marginally supported, span, attached primarily at the ends, kind of like a simple bridge, except that the transom is also attached to the hull bottom, so it is more of an oil can flex - imagine cutting half of the top out of a 55 gal oil drum, then grip the edge, in the center - it would move up and down - any unsupported edge would do that -
It seems that cracks primarilary start to appear at the lower corners of the transom motor well cutout - leading me to suspect that most transoms are not adequately reinforced by inherent design, so that as soon as the core wood gets wet and begins to lose it's stiffness, the load is shifted into the glass, which if not overbuilt, soon begins to fail under the increased load - thus the cracks forming.
Imagine a straight line, width of the transom, fastened only at the ends. From underneath the line, you have a force, up against the line - now add - above the line, imagine a structure in the letter "W" sitting on the line, above it, in the center - the two bottom points of the W are on the transom line, the two upper points of the W are fastened to the boat hull - either directly or indirectly thru the cap -
the more strength in that center support, the better off the whole transom structure will be.
just my humble 2 cents worth.
Bill
Old 08-04-2005, 04:24 AM
Bill you are putting me to sleep with all that darn engineer talk [img]/images/graemlins/grin.gif[/img] Just put it back together and I'm sure it will be fine....A buddy of mine is a structural engineer and a while back I asked him how I should go about testing an engine bracket that I built. His reply was bolt it to a wall and then put double the weight you anticipate it to bear and then jump up and down on it for a while and if it does not crack then you will be ok. This guy was on the discovery channel for some engineer competition thing and his team won [img]/images/graemlins/shocked.gif[/img] I like your boat and hope to find one like it some day over here on the left coast. Good luck.
Old 08-04-2005, 04:16 PM
HeHe I have a friend Robert Sebring that own's Dawson Boat's here in Pensacola. http://www.rlsebring.com/
He had made some test panel's and sent them to Pensacola Testing lab. The panel's were cored with 3/4in Nidacore.
They came back and said XYZ strength, bla,bla,bla. Robert said wait a min. Give it to me in layman's term's. Can 30 people stand on top of this hardtop?
They said 300 people can stand on it. [img]/images/graemlins/shocked.gif[/img] [img]/images/graemlins/crazy.gif[/img] [img]/images/graemlins/grin.gif[/img]
This was not on a center console [img]/images/graemlins/crazy.gif[/img]
Old 08-05-2005, 01:27 AM
Default back to work - the inside story
ok - so last we saw, the keel had a hole in it, and I wanted to brace the transom with a knee, to stiffen and prevent any further cracks from developing in the splashwell, or transom corners - as seen
so tonight I crawled underneath, ground off the gel coat around the transducer hole, and beveled the hole out a little - I had already slabbed a couple pieces of 3/4 ply on each side with RW and thickened epoxy
here is the partially filled keel hole, and the knee brace
and here is another shot of the knee - it's two shorter pieces of 3/4 ply bonded to one longer one, which is slabbed onto the side of the keel, again with epoxy soaked RW and filled epoxy butter
I ran the knee up to the top of the inside transom stiffener plate, both of which end right below where the splashwell comes up to the transom
Tomorrow night I'll go back and tab the knee into both the keel and the transom support plate. Then I should be positioned to put the outer skin back on this weekend.
Bill
Old 08-08-2005, 01:58 AM
Default the skin goes in -
sun night - took all weekend - maybe I'm just anal about details and prep - oh well.
a running picture story -
Sat morning
pull off the cover and get ready to work
set up the work bench - I like 3M blue painters tape and wax paper - an easily renewable work surface
first real job, cap the new transom with several layers of cloth / epoxy resin, using some quickie molds to help hold the shape
now pull the molds off after that cured, and do a little sanding
now to start prepping the outer transom skin - I had previously ground clean the inside surface, but still needed to do the outside surface
and then grind back the edges, both on the skin, and on the boat, so it would be ready to tape the seam after installation
and then trial fit - it came out of that hole - would it go back in ?
mixed up more sauce, backed up the skin with a piece of RW, wet the core, skin and RW out, and installed
Halleluja !! the Skin is In !!!
word to the wise - this is a butt busting, dirty job - don't undertake this lightly.
On the flip side, rap the new transom with a hammer and hear the sharp, distinct sound of SOLID .... I like it !!!
Bill
