Old 09-20-2005, 12:29 AM
Default Re: Potter 23 converted from Diesel to Outboards
Here are few shots.
Old 09-20-2005, 12:11 PM
ScottM ScottM is offline
Dieter Sprockets
Snookered,
Does the boat still have the tunnel from the old IB running gear?
Old 09-20-2005, 02:45 PM
I'm not sure on the running gear tunnel - the access point in the deck in front of the console is where your talking right? It looks to be the tunnel in the bildge and it is pretty wide open between the two fuel tanks. I just had a surveyor over and said that the moisture was low on the transom, except for a small spot below where the transducer was. He gave me a thumbs up on the structural integrity for the whole boat. This boat is 95% put back together, I have to meet with the original mechanic who converted the the power and electronics to get a once over done. I am going to need a hinged t-top, so the current incomplete top is no problem. It's only momey!
Old 09-20-2005, 06:22 PM
Dieter Sprockets
No, I mean the tunnel on the running bottom where the shaft, strut and rudder would reside. Perhaps Miles Offshore can post a pic so you can see what I mean. I'm curious if it's still there because I would think it would cause some issues with the OB props grabbing clean water.
Old 09-21-2005, 12:05 AM
Scott-
It has been completely filled in and glassed over to look identitcal to what the outboard V hull looks like. It has been well done. Thanks for the insight to what the hull used to be! I will now be better focused to inspect this area of the conversion-thanks Scott!
