Old 09-22-2005, 01:10 PM
WillyC WillyC is offline
Default Re: \"glue and screw\" question
Stoney,
Can you be a little more specific about how you made the tee out of 2x6's. Also did you use any releasing agent on the through bolts. I will be using the same materials as you, coosa board, epoxy and biaxial cloth. I also checked out two pictures that you posted and it looks like you have a 23' sf. Do you thik the transom on the 20' needs additional structure or support aside form the original setup? Thanks -Will
