Old 10-27-2005, 09:24 AM
caper caper is offline
Default Re: My first
Quick disconnect hydraulic fittings are available - I have used them on brake systems on race cars - to facilitate removal and replacement of rear axle housings. We did not have to bleed the brakes. Sources would be Aeroquip or Wilwood.
Old 10-27-2005, 04:59 PM
all great ideas and thoughts, thanks for that. I am still going to try to have everything stay connected. If that doesen't I will have to get creative i guess. thanks guys.
Hey, another question for ya: If I get a plotter/fishfinder unit can I use my current thru hull transducer or do I have to install another one?
Old 10-27-2005, 07:08 PM
warthog5 warthog5 is offline
Depend's on what unit you have, what unit you buy and if the plug on the end of the cable are compatible.
Old 10-28-2005, 11:15 AM
yachtjim yachtjim is offline
What's the big deal about making the whole thing tilt forward? That is how one of our Seacrafts is set up and there is absolutely no issue with any of the cables or hoses. We are going to make ours powered up and down too. If you already have Bennett Tabs then you can use the Bennett rams. These are special rams for doing stuff like this. You have a lot of weight there so I'm not sure how much lifting power you will need. There are bunch of comapnies that make worm gear style rams too.
www.BOEmarine.com - Marine Electronics and More
www.ByOwnerYachts.com - Innovative Yacht Brokerage Programs
Proud owner of a 1976 23' Seacraft CC.
Old 10-30-2005, 05:43 PM
Here are some more pictures of the gelcoat and the completed project, minus windows, on the boat:
The gelcoat will not be polished. Total time to completion was 1 day to frame, 3 days to glass, and 1 day to gelcoat (2 coats). Not bad for a rookie if I say so. What do you guys think.
Old 10-30-2005, 06:04 PM
Tarpun Tarpun is offline
Great work. If I lived up your way I'd probably do the same only narrower for my 20MA. It's got the large console that I will probably make more narrow so I can install a T-top. I had thought about mounting one similar to your original but guessed it wouldn't be as solid as I would like. About how much of the 400# do you guess the console was?
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 10-30-2005, 06:22 PM
probably about 300 lbs for just the console, she was a heavy b@st@rd.
