Old 01-27-2006, 03:38 PM
Trayder Trayder is offline
Velvet Jones
Default Re: Gel Coating Vinyl Ester
It depends if cured or not-
Vinylester resins utilize a polyester resin type of cross-linking molecules and if applied "wet to wet" on poly gelcoat it will chemically bond. (like in a mold)
If you are doing a repair with vinylester resin, you should use laminating resin. Laminating resin stays tackyas it will not fully cure when exposed to air, this will allow you to get a chemical bond between the final layer of gel coat with wax or gel coat covered by PVA.
If the vinylester resin has cured, rough it up and shoot your gel-coat, the mechanical bond will be more than suitable.
