Old 03-11-2006, 04:06 AM
Fishjack Fishjack is offline
Default Re: Yet Another Transom Job in the Works - ?ions
Strick -
I opted to go with an 11.5 inch high tank vs. the stock 12 to add some extra room for the plastic strips fuel fills etc. I won't loose that much capacity for convience.
BTW - I made this decision after reading one of your old post about having to remove your plastic strips. Live "read" and learn.. thanks
I figured if I am having a new tank built to spec I would make room for some sort of support/drain etc. & make it eaiser to connect the fill and vent hoses under the console.
Speaking of fuel tank coating - I just had my old transom bracket powder coated and I am debating on powder coating my new tank vs. epoxy coating vs. coal tar. I can get it powder coated for $3/sq ft. Pretty good price. BUT I am WAY over budget now on this "replace the wood in the transom project"
I take it Tap's Plastic is an online source? I have looked at Home Depot and Lowe's cannot find anything suitable other than some extra thick blind material.
Here are a few pics -
New fuel tank support plywood ready to coat -
The old "stock??" transducer - (mentioned earlier in this thread) was almost under the tank...????
Removal of the old transducer -
Powder coated transom bracket - D&D Marine - Originally installed about 7 years ago...
The filler originally used to bond the deck with the stringers on the port side had broken loose.. I used epoxy/filler to replace it... The starboard side has a hairline crack and I will probably replace it as well... The old stock filler easily popped out with a chisel??? Just goes to show the possible weakness of a polyester/polyester bond...
FWIW - This is my 1st time using epoxy resin and it is GREAT stuff.. Working on these small projects has helped me learn the cure time / filler mixing proceedure etc. etc. before the transom goes in.
Very easy to work with but the FAST hardner is truly FAST...
My 1st batch with filler hardened b4 I got it out of the pot...
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
Old 03-11-2006, 04:19 AM
c_e_carter c_e_carter is offline
Matt, Never said I couldn't get up there but I had the mental picture of a Walrus doing the Worm on the T-top. That didn't sound like the photo op I was looking for.
Jack, Sorry to hijack you thread. Everything is looking great. You are obviously busy in you time off. Keep the pics coming.
Chris..
87' Mako 231
Old 03-11-2006, 06:23 PM
Decided - to save weight in the stearn I would use some high tech foam board -
Just kidding but I wanted to try this R-max for a template and it cuts easy - is stiff and light. Worked pretty good.
Rough cut the marine ply and bonded - using just about every clamp I had - and some water for weight.
1977 23' Superfish
ST250x Yam
Old 03-11-2006, 07:01 PM
warthog5 warthog5 is offline
Looking Good Jack. I see you used the milk jug cap's.
Old 03-11-2006, 10:07 PM
Yep - Bobby they worked great... I opted for the foam insulation board instead of the luan for the rough cut pattern.
Seems to work pretty good.
1977 23' Superfish
ST250x Yam
Old 03-11-2006, 11:37 PM
lost2a6 lost2a6 is offline
Looks great, I wouldn't mind easing over your way and checking out your progress some time.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 03-12-2006, 02:30 AM
Steve - your more than welcome to stop by anytime...
1977 23' Superfish
ST250x Yam
