Old 03-19-2006, 09:56 AM
TUGBOAT TUGBOAT is offline
Default Re: Yikes!! - Replacing Battery Cable Terminal Gauge
PeterB,
If possible just change it.Chances are that the corrosion has gone up inside the insulation & will follow the wire like current. It'll go bad inside. This is one of My preventive maint. Things. I change them every couple / 3 years. Measure how long,Go to NAPPA or other Quality auto store & get the ends crimped or soldiered on. I use welding leads- Always bigger than needed.Or marine grade (best).
If You use the old then cut back till Clean wire is visible.Weakest link in the ignition system!
Scream'n reels'
Tug
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
