Old 02-26-2006, 09:43 PM
Jaizzen Jaizzen is offline
Default Anyone out there with Twin 150 Yamaha Motors?
Looking for some perfomance data from guys running twins on their 23' Tsunami or Sceptre.
Thanks, Jason
Old 02-27-2006, 07:19 AM
CapeBoater1 CapeBoater1 is offline
Default Re: Anyone out there with Twin 150 Yamaha Motors?
I have a 23 Grady Gulfstream with twin 150 Yamahas. The performance data on that is a cruise speed of 30-33 and top of around 47. The gulfstream has an identical deadrise at the transom and is a heavier boat so your performance would be similar I would "GUESS".
Old 02-27-2006, 03:16 PM
Thanks for the input! I was hoping for a 30 kt cruise. Top end doesn't mean much to me. How about fuel numbers?
Thanks again fot the information.
Old 02-28-2006, 08:59 AM
peterb peterb is offline
I have twin 1998 Yamaha 150 Salt Water Series engines. They have carb's and like gas alot. They are on a 23 foot SF SeaCraft. I may average around 1.5 miles per gallon (if I'm lucky).
Old 02-28-2006, 10:36 PM
Thanks for the info. I'll put my numbers up as soon as I splash the boat.
Jason
Old 03-23-2006, 09:47 PM
PeterB, What props you running? What type of load do you carry.
thx, Jason
Old 03-23-2006, 10:51 PM
Jason,
I have stainless steel 17-M props.
For boat weight I come up with around 5,600 pounds
(boat & t top = 3000 pounds) + (2 engines = 838 pounds) + (mostly filles 150 gallon gas tank = 900 pounds) + (3 fisherman and other misc stuff = 600 pounds)
Also, I use 12x12 Bennett trim tabs
What was the question again? Hope this helps.
Old 03-23-2006, 11:23 PM
Thanks for answering my question. I too have the m-17 props. I have the same fuel, same motors (not installed yet). I have a Tsunami. I will be considerably heavier with scuba tanks. Just trying to see if i'll be propped right.
Jason
Old 03-24-2006, 10:10 PM
Oh, and I get up to around 5,400 RPM's at WOT
Old 04-23-2006, 12:03 AM
So what kind of performance numbers did you end up getting?
