Old 07-17-2006, 07:19 PM
RS RS is offline
Default Re: Ladder building material
The question: What is a really lightweight material that is strong, maintenance freeand easy to work with ? i.e. the properties of wood, but lighter ? Starboard might not have the needed strength to hold bolts laterally...
Thx
Starboard and trex are about 3x the weight of wood. I think the closest thing you'll find to what you want is ... wood.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 07-17-2006, 07:59 PM
abl1111 abl1111 is offline
I agree, wood is the lighest I can think of. Fiberglass sounds like too much hassle to build - it would be a lot of layup to make something that would need strength in every direction.
I was hoping one of you guys knew of some great 'stuff' that met the criteria.
I am still open for ideas though.
The original ladder was perfect - however not great quality. It looks like a it was a moulded pastic but there are a lot of voids in key areas (that's why my ladder failed, at least ). But, the design is perfect.
Old 07-18-2006, 06:53 PM
jongolds jongolds is offline
I'd love to see what it looked like and how it stored as well. Mine also was stripped of this.
In the meantime, I was going to try an build some sort of ladder early this year but I've found that with the plywood panels that I put in to fill in the v-berth, it's not a bad step up to get on to the bow anyway. It's not great mind you but it wasn't bad enough to put that much work in to.
The best I could think of before I'd abandonded my ladder idea was PVC tubing but, I was told it wouldn't last if exposed to UV rays from the sun so then I thought of metal wire conduit..which of course would rust. Maybe those ideas can help get you somewhere though.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 07-19-2006, 12:13 PM
RS RS is offline
Maybe you can rework part of an old/cheap extension or step ladder made of aluminum.
Best regards,
Roger
Old 07-19-2006, 05:14 PM
Its the folding aspect you have to consider, if it doesn't fold up like the original it would be a pain to store, that decking stuff would work as well I bet a bunch cheaper.
Old 07-19-2006, 07:11 PM
Here is a picture of the ladder. It's really nice if it works correctly. I would like to build another and if anyone has some insight as to how - I'd like to hear about it. Main requirements: light, durable, maintenance-free, foldable.
[image]http://[/image]
Old 07-19-2006, 08:47 PM
RS RS is offline
I'd use starboard side rails and wood treads, unless you need it lighter - then use all wood. Teak with oil is pretty maintenance free.
Best regards,
Roger
