Old 10-18-2006, 11:50 AM
Default Re: livewell on 20 ' 1978 MA
The in-deck livewell issue of filling with rain water or water when washing down the boat is a problem with all SeaCrafts apparently. I have a 2000 SC21 and this drives me crazy. I would love to have the leaning post/above deck well that is optional on the 25- its not an option on the 21. Those Armstrong deck plates aren't the greatest by the way- the gasket lasts about 2 seasons tops then have to replace and the deck plate itself is very difficult to remove and replace unlike deck plates that have a base to screw into (this one does not- removes as one piece)
Old 10-18-2006, 12:05 PM
GradySailfish GradySailfish is offline
I have a 78 MA, and it has the same configuration as the drawings, although I originally had a 70 gallon tank that took up the space up front. I bet your live well config was after market desing/modification.
I repalced the 70 gal with a 55 gallon tank, which freed up something like 24 inches. I was going to push the tank all the way foward and convert the area behind the tank into a well (i.e. make a bulkhead, seal and plum), then I changed my mind and plan to fill the void with foam to increase floatation in case "something" bad happens. I moved the tank as far foward as the coffin permits as I want to keep her from being ass heavy!
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
Old 10-18-2006, 06:52 PM
CaptRJ CaptRJ is offline
I have an interesting situation here in that I see the man who actually sold this MA back in 1978 a couple of times a week in the shop I work at.. He owned the SeaCraft dealer here in Ct back then . . he confirms that the baitwell is factory original and the original SeaCraft manual that came with the boat shows the well also. I guess I will research as many hatch manufacturers as I can and try to find one that makes a good watertight hatch that I can modify into the current opening.Thanks for all the input .
Roger
