Old 10-29-2006, 08:42 PM
Default Re: tubes for deck drains
I have some brass tube left over from my Whaler tube replacements. What diameter and how long??
Old 10-29-2006, 11:29 PM
the tube is 1" diamater and its about 3.75 to 4 inches long... is the tube u have flared on one end?
thanks
Old 10-30-2006, 11:13 AM
Not flanged, It's easy to do. You have to anneal it by heating the end to be flanged cherry red and immediately quenching in water. Flange the first end, cut to desired length leaving 3/16" - 1/4" for flanging the second end, quench the second end, apply sealer and/or o-ring (I have those too.)install in hole, flange the second end in place. There's a lot of info on the whaler site...www.continuouswave.com
Old 10-30-2006, 07:43 PM
Reel
u said u might have some leftover tube. is that still the case? let me know.
Old 10-30-2006, 08:50 PM
I have 28 1/4" and the o-rings to fit. It's yours for the shipping cost. Don't be scared of the flaring part. Once it's annealed it bends really easy without cracking. It's too brittle otherwise. The more square and accurate you cut the ends, the better it looks finished. The second flange is a two person job.....one to hold/one to hammer (an old towing ball works nicely!), or sometimes your local Whaler shop will rent (or lend) the flaring tool. All this assumes the tubes are flanged on both ends and capturing the hull against both flanges.
Old 10-31-2006, 12:31 AM
reel
if the stuff u have is 1" in diameter ill take it. ill PM u for shipping.
Old 10-31-2006, 05:12 PM
abl1111 abl1111 is offline
I have seen some really nice work on this site w/ PVC set in epoxy. I re-did my 'tubes' (3) years ago and if I were to do it again I would do it the epoxy/PVC way.
