Old 12-10-2006, 11:11 PM
bobbert bobbert is offline
Default Re: Dashboard Re-build
PLEXIGLAS IS NOT A GOOD IDEA. UV AND COMPRESSIVE FORCES WILL CAUSE WHAT IS CALLED CRAZING. (SMALL CRACKS RADIATING FROM THE CENTER OF THE HOLE)
STARBOARD A BETTER OPTION.
BOBBERT
Old 12-12-2006, 02:52 PM
Mine was redone with starboard, very easy to work with.
Old 12-13-2006, 09:56 PM
TUGBOAT TUGBOAT is offline
Made a mold of the old wood/teak dash.Glassed it. I was worried about leakage around the gauges-radio-electronics as I didn't know anything would seal it(Starboard).
Scream'n Reels'
Ever stop to think and forget to start again?
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 12-13-2006, 11:47 PM
oz775 oz775 is offline
What did you make the mold out of? Did you just glass over the old dash? I thought if I silicone or caulk around gauges/ electronics it would keep it water tight. What do you think? Thanks for everyones input.
1974 Tsunami- 2004 Merc 225 Opti on bracket
Old 12-14-2006, 08:48 AM
Sleeto Sleeto is offline
I am in the process of redoing my dash for the second time in 2 years. I decided that I wanted the chart plotter directly in front of me, over the steering wheel. I put the guage cluster in the middle.
Used 1/4" Starboard both times. It is easy to work with, cutting holes and routing the edges.
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
Old 12-15-2006, 11:08 AM
I took the original dash & made a copy of it.waxed layed the ol' fiberglass then popped it out. Then did sll the fun stuff to make more dshes. I had the mold stored where it was made so more could be copied buttttt someone decided it was either No Good or better in their shop. Came out really good. Painted it with a 3 part primer. it self seals if not painted over after 12 hours so it isn't reflective/bright glare. drains built into it & sliding plexi doors.I also opted to have the GPS in front of Me everything else is readable from the helm. there may be more pics on the site/link below
Tug
www.frenzie.com
