Old 12-15-2006, 09:17 AM
Default Re: Live Well Worries?
Looks great!! Where does it overflow and where does it drain??
Old 12-15-2006, 11:15 AM
This is were I got it:
http://www.casdvm.com/photos/Leaning...well/index.htm
The drain is on the starboard side of the boat at the water line.
The overflow is is above the water line on the port side. Hopfully you can see from the pics were the thru holes are located. The plumbing is under the deck.
Old 12-15-2006, 01:51 PM
Very nice!!! I've always admired your boat!
Old 12-15-2006, 06:50 PM
I have the same Kodiak livewell and does a good job on keep bait kickin.
No clean plumbing since i take on/off the deck when used.
I use some of that noslip material under you find a HomeDepot. When 1/2 or full, the never has the tank moved in some serious slop. If it ever does move, time to empty and get my ar$e in ASAP
I picked it up used and try to keep the sun UV off the fittings. It may take a while, but the plummed fittings were badly cracking/leaking and they are plastic welded into the tank.
The only other note to add is when i put my Suzuki in the water, it does not change to a Yamaha like Strick's
maybe, because i am running a 20' not a 23'
- Nick
Old 12-18-2006, 09:34 PM
- Nick
Bottom Paint too!!
Old 12-19-2006, 08:29 PM
Ryank Ryank is offline
Hey Strick is your T top Powder coated or epoxy painted?
I need to do something to mine and not sure what direction to go in.
Seacraft's for life !!!
Old 12-21-2006, 12:38 PM
It is powder coated and holding up fine.
