Old 12-27-2006, 06:41 PM
Bryan A. Bryan A. is offline
Default Re: 1973 20 SF changes/improvements and a question
It's from the air in the mixture. You could try mixing slower although I have found that doesn't help much. Or use a high build primer after the fairing is complete. I'm sure others will chime in with recomendations.
You could also use a premade fairing compound. I have seen others use Quik Fair by System three, it is packed under a vacuum so no bubbles, but I have not used it myself so I do not have first hand experience.
Hope that helps, Good Luck. Pin holes suck.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
