Old 01-12-2007, 11:24 PM
Default Re: Suzuki 250 4 stroke
What is almost unbelieveable is that strick's boat hits 6K easy and will bump the rev limiter with 3 200lb guys and a full tank. I'd be interested to see how his boat would do with a 21pitch.
Old 01-13-2007, 12:12 AM
warthog5 warthog5 is offline
Sound's like she has more room for tweaking.
Old 01-13-2007, 03:05 AM
I'm no tweaker so I wont be changing anything for a while. I'm really happy with the way it performs. It get's up and goes. It seems every bit as fast or faster then my Yam 250 2 stroke was. Trim tabs are a must because the extra weight/speed that I now have will make the boat porpoise slightly. Easy to adjust by tabbing down slightly.
Old 01-13-2007, 09:15 PM
With the motor hitting the Rev limiter there is room for some more pitch to be added.
It may slow the boat out of the hole by 1 or 2 secound's, but so what.
It should increase the top end speed and lower the cruising RPM to get even better fuel millage.
Old 01-14-2007, 05:38 AM
Chuck - I'll keep my eyes peeled for a Rev4 19 or 21. You know you want to tweak that boat.
Old 01-14-2007, 12:05 PM
With the motor hitting the Rev limiter there is room for some more pitch to be added. It may slow the boat out of the hole by 1 or 2 secound's, but so what. It should increase the top end speed and lower the cruising RPM to get even better fuel millage.
Peer Pressure.
Old 01-14-2007, 12:40 PM
HeHe Think $ in fuel savings.
