Old 02-23-2007, 07:08 PM
hermco hermco is offline
Default Re: mold lay-up problems need help
Probably what is called alligators, when the gel is not properly catalyzed or mixed and not cured in areas when you put on your check mat. The gel will "crinkle",bubble, and look like alligator skin. Just finish your laminate and then grind out and putty the gators on the part after you pull it from the mold.
