Old 03-07-2007, 10:35 AM
JW-Tex JW-Tex is offline
Default Re: 50 gallon livewell in a 20'
Putting 400 lbs in front of the console...should work (like two passengers), I run a 30 gallon tank in the same spot. I install my tank only for temporary use. The hoses are run to the acess hatch on the front casting deck (the access plate to get to the drain for the fishbox) and I open that hatch and pull the hoses out when I want to use it. I put a larger thru hull where the fishbox drain was and use that for the overflow.
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
