Old 06-12-2007, 11:20 AM
bigeasy1 bigeasy1 is offline
Default Re: Flipping a Hull
A few years ago we did this to a 21' older Aquasport ctr console.We put two slings around each end of the boat,and hoisted it up to the steel trusses in the wharehouse we kept it in.
We ran the slings thru pulley blocks,and once we had it elevated we just turned it over.It actually was fairly easy to rotate it.
Once we had it flipped,we set it on some wood bracing we built at waist height,so we could work on it.
Maybe you could use something similar to this,it worked well for us.Good luck
All this,just for a boat ride
