Old 07-18-2007, 09:39 AM
bdolnik bdolnik is offline
Default Re: 77 23' Savage
Pull the dipstick. If the oil looks new, then I am sure you can get away with out doing anything.
Yea that's what the guy who sold me the engine said to do, that and check the filter and change it and the seals. Said you really don't have anything to loose. Luckily on this boat I don't think you have to pull the motor to get the tranny out. It's all very accessible when you pull that back deck up.
New motor actually arrived yesterday while I was down there cleaning out the bilge, that was VERY quick, didn't expect it that soon. Just ordered it on Thursday.
Old 07-18-2007, 08:49 PM
Tanks are out now and they don't look too bad. They were epoxied on bottom and sides so may not be originals. I don't know, any chance the factory would have done that on the Savages?
Also can anyone explain how the blower system works on the inboards? There is a blower/motor in the stern on the port side, hooked up to large flexible piping. The piping goes to the rear vent and I believe the forward vent. On the starboard side the flexible pipe is there but it's not hooked up to the blower.
Old 07-19-2007, 09:59 AM
If you look at the tanks some place near the filler there should be a plate or sticker that tells when they were made.
As far as the blower, think of it as a vacuum cleaner. It's job is to suck the air out of the bilge. So one end of the hose should be in the low part of the bilge and the other to an exit point. The other hose is to allow circulation while the boat is running under power. That way the blower is not on at all times. The bilge air is then removed by a venturi process. Hope this helps.
Old 07-19-2007, 08:43 PM
BigLew BigLew is offline
This is possibly a minor point, but I learned (and it makes sense if you think about it) that the blower should be mounted so that it sucks fresh air in and delivers it to the bilge/below deck areas where it will be forced out the remaining vents, along with the air in the bilge go any accumulated fumes from fuel, etc.
If you mount the blower so that it picks up the bilge air and pushes through the blower and then out through the vent, you run the risk of drawing up fume laden air in the bilge and forcing it past an electric motor that more than likely is creating sparks at the armature portion to the electric motor; a potential disaster!
Because of this, it is recommended that the blower be run for 5 minutes prior to engaging the starter or even turning on the ignition. In our boats this should provide time for about a three to five fold exchange of outside air through the bilge.
Just my 2 cents.
Plan accordingly!
Old 07-21-2007, 09:33 AM
You could be right on this. However I believe the blower motor is built so that it will not spark on start up. I think they call this spark arrested? Anyway the best test is the nose test.
Old 07-21-2007, 11:11 AM
You are likely right, however. I witnessed a teenager jumping into a Donzi equiped with an I/O tied to a dock on Lake Murray in SC. He didn't run the blower and immediately turned the key. The explosion not only destroyed the boat but killed the boy and injured a near by observer.
As contributed on another thread on this site, my personal policy is to run the blower for 5 minutes WITH the engine cover lifted with no one else aboard, if at all possible, prior to cranking the engine.
As I said, Just me 2 cents.
Plan accordingly!
Old 07-21-2007, 11:56 AM
in my boat I have two hoses on each side ,
1 on each side that goes between the hull and liner near the stern that naturally asperates(sp), and the other two that run directly in the main bilge and on one side I have the blower installed (exhausting outward. ) Nothing works better than a sniff test- one before starting, one before and after fueling. The bl=ilge blower motors are sealed so no sparks from them. You dont want to be turning other switches on and off while fueling though. craig
