Sounds like wrist pin or rod bearing.
![]() ![]() Compression test should tell if it is top end or bottom end. Good Luck with it Bill, Keep us posted. Ken
See ya, Ken © |
Ken, et al -
I believe I got lucky, it was a soft hit, probably carbon, that pushed in the electrode. Con rod bearings are fine, compression is good, 115 - 120 all cylinders, visual examination shows everything good, closed it up and ran it on muffs - sounds just fine. Goin back in the water - just not this weekend - I'm off to the Vineyard for the shark tournament !! Bill |
