That looks great strick!!!!
Chuck I see you have some blobs in very small areas as your filling stuff.
Go get you a box of single edge razor blades.[100 count box] Use the razor blade as as a spreader. when done chuck it in the trash. This will keep from having filler spread all over where you don't want it and concentrate it where you do. You will find it as a time saver. ![]() |
Dummy here has a whole box of razors but forgot all about that trick
![]() strick
herning is a great place, glad they saved you some money
Jeremy |
Time for an up date. I've managed to get a little done on the boat over the last couple weeks. I had a couple quarts
of awlgrip left over from my 23 project so I decided to go ahead and paint with that rather then Imron. This boat will sit on a trailer most of it's life. The bottom is painted with a 50/50 combo Mattahorn white and Off white. I got a nice hatch from TH marine. Cast aluminum and the lid comes completely off for easy access to the bilge were the seacock and one of the bilge pumps will be. Cut outs for deck hardware: Some of the hardware that will be going on the boat. The Accon LED bow light is really slick: I used the gantry crane to slide the blocks and supports around so I could finish painting the bottom of the boat: I was able to get the boat on the trailer by myself using the gantry crane: It fits in the shop nicely: My son caught this 13 pound catfish in the canal behind our house the other day: He caught it plugging for stripers using a 1/2 ounce rattle trap on a ultralight pole with 4 pound test. Dad had to help him a little. ![]() since I was able to get the boat in the shop I felt like I was on a roll so I decided to finish painting the outside of the boat. The 545 awlgrip primer was sanded with 220 using a DA sander and hand blocked as well. Masking it off: tack coat applied: Successive coats applied: As you can see I was painting late in the day. Not a good idea. The bugs were not a problem but visibility was. I could not use too many lights or my breaker would kick off because of the voltage drop with all my cords strung out from the house. At any rate I got it painted. After Looking at the paint job in the sunlight the next day I decided that I could not live with the way it looked. There were some areas that needed to be sanded more. Everything was nice and smooth however some of the areas were I added filler were too high and needed to be sanded down more. So I broke out the sander once again. Then Re-sanded the entire boat and primed the areas that needed it: Then back in the shop for re-painting: It looks better now. Something I think I can live with. strick
Nice!!! Looks like you'll be ready for my Parker soon.
![]() ![]() ![]() Love that color. Tell your son nice catch from New England. ![]()
May all your deadrise be variable. My 1973 SeaCraft 20SF Parker 2530 DVEC Boston Whaler 15 1984 |
Strick, nice work ! I think I like the Fighting Lady Yellow, but I think I'll be doing Ice blue for my 20...which is nearing its paint stage.
I applied some 545 today and noticed that it looks like I can see the body work underneath. The thing is, when I run my hand around the area, it feels smooth, when I apply a ruler its fair, but it looks like the body work is coming through the primer. In your first primer picture you had a similar mark through the primer...do you think more coats will cover it up ? Other then that the my hull is super smooth, only the top cap somewhat concerns me. Alex
2002 26 Fortier Yanmar 250 6LP-DTE 1978 20 Sea Craft Master Angler 08' 150 ETEC |
Damn, Strick pretty work!! I haven't been on the site lately ,she is looking great!!I like the color,that's the same color I just painted the carolina boat with.
Thanks again for the local knowledge. Joey |
