Old 08-23-2007, 12:50 PM
Default Re: please help me settle argument
Evan - the guy is -half- right... I have a 73 Seafari, same hull as a cc... there is a glass wrapped wooden stringer at the keel, BUT, the 2 main stringers are large glass boxes filled with foam - and I will guarantee these have never been replaced, as I'm the second owner of the boat since new, and talked with the original owner when I bought her.
Now, pre '70, I believe the 20's had a glass wrapped wood stringer matrix, but, this was changed, from all I've read / heard / seen, in '70, to the foam filled glass box stringers you see in the picture above - but even thru the '70's they still had a wood keel stringer, wrapped in glass.
So, half right, but not - the main stringers are foam filled glass, as originally built.
hope that helps
Bill
Old 08-24-2007, 12:16 AM
i didnt even think about that keel stringer. i swear i remembered reading in the 73 brochure on the site that it has 2 faom filled stringers in it. thanks guys! next time i talk to this guy im sure he'll have some more "seacraft facts" for me.
Old 08-24-2007, 02:08 AM
Dido here with a 72 SeaFari (2 big box fiberglass stringers . . . center keel is wood) and the earlier 4 stringer setup were empty fiberglass shells with a wood center keel stringer.
I don't consider the center keel a stringer.
Old 08-24-2007, 03:31 AM
You are correct, they all had 2 main glass box stringers, no wood at all, they then had a wood keel stringer that really wasn't a factor in rigidity as the box stringers carried all the weight.
Old 08-24-2007, 10:11 AM
I remember a thread where someone asked Potter about the keel stringer and that it was added because many boats were trailered....and back then I think most boats sat on keel rollers......
Old 08-24-2007, 10:38 AM
hermco hermco is offline
Yep. And Bill told me he came up with the foam for stringers from a cousin at Rockwell Intl.
Old 08-24-2007, 11:28 AM
warthog5 warthog5 is offline
FYI: Technically that is called a "Keelson". It's on the inside of the hull.
Old 08-25-2007, 08:55 PM
i knew i could come here and get the answer that i needed. thanks so much! i was pretty sure that i know my own boat.
