Yow! Sorry to hear that! Hope none of the engine electronics were submerged.
I have two bilge pumps, two float switches, and two batteries in my Seacraft. Each pump is wired directly to a separate battery through a separate float switch. So there are two complete systems that are independent of the battery switch. Cheap insurance. Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
Some engine electronics were submerged. But only for a short while., everything was immediatly rinsed with fresh water and corrosion block/wd 40.
Hopefully that did the trick!
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150 http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg |
Someone else had the same problem within the last year and it caused me to install a high water alarm. You would have heard it going off long before it went under.
70% of the earths surface is covered by water...It's going to be a very long day...Florida Marine Patrol. |
How much does a high water alarm cost? Sounds like a good idea!
![]() Quote:
Dave
![]() Quote:
Hello there,
These are all very good idea. When i was new to powerboat, David Pascoe website provided a wealth of information to get a boat seaworthy. - seal the opening to the bilge (hatches, holes, cable entry) - double bilge pumps, electrical and battery ( as mention above) - for those with rear drain (install scupper) - seal the big livewell in the back especially if not in use. This would provide plenty of flotation. - bilge alarm -etc |
