Heck, it looks fishable now. If you dont want to do a complete resto do a sniff test in the fuel tank compartment, if no smell its probably ok but a pressure leakdown test would be better; hook the trailer to your vehicle, tilt the motor up and jump on the lower unit. If you dont see any flex in the transom where the motor is bolted then it should be good for a couple years; next, walk the entire deck, if you feel any soft spots jump on them a little, if ya dont fall through, the decks alright for a while; check your wireing for corrosion and loose connections spray some B-9 on the terminals and check that everything works; check steering and control cables ; check your bearings and tires on your trailer; If everything seems ok , go fishin
IMO , I wouldn't waste the time or money to paint the inside unless I was going to do a total resto; I would fill and protect any screwholes to prevent any water intrusion..I'd try somekind of finish restorer on the outside before I repainted. Take the time to do searches on this site and you will find everything you need to know, Richard
" I'm the one thats got to die when its time for me to die; so let me live my life, the way I want to". J. M. Hendrix |
You need to make sure the deck is solid enough to hold a tee top. if it is the orginal deck it may not be! just something to think about!
That is a nice boat, it was for sale here as well. My father had the little brother to your Suzuki 140, the 115, on his 19 mako and it is a GREAT motor. Had some odd corrosion but was great on fuel and oil.
welcome aboard. |
Oh, the transom is only a couple of years old and the deck feels fine. My concerns are that the tank is in the console and I would really like a smaller footprint on the console so that a cooler could be upfront instead of a seat only. I realize it is fishable now, but want to do a half redo; as in paint, leaning post, t top, cushions, livewell, trim tabs. I just need to figure where to start. I guess ripping everything off to prepare for any fiberglass work and painting would be first.
Thanks for replies. |
Changing up the console is something that many of us here have done. I cut four inches out of the middle and removed the seat in the front to make room for an ice chest. I think it is right at 28 inches wide now - just about the same width as a 94 quart ice chest.
![]() ![]() ![]() I'm not certain about your boat but you may have to deal with a raised lip that the console is attached too. If your tank is in the console, I would think about putting the gas tank in the floor like the newer boats. This would be alot of work as you would have to cut a hole in the floor, fabricate a hatch cover and lip in the floor for the hatch to rest on. In my opinion, very worth it to get the tank in the deck where it belongs and free up space in the console. -will |
Can some other people post pictures of how they modified this version of the 20'CC console?
here is some pics of when i did mine. i have the same console as you did .
