My father is a professional auto body refinisher and works for the local Peterbuilt dealer here in Hawaii. Spraying AwlGrip, Imron etc. is very deadly and should only be sprayed while using supplied air systems. He also worked as a paint rep for Sherwin Williams and learned about how they make paints as well as the hazards of using them without Personal Protective Equipment. Check out the MSDS (Material Safety Data Sheets) and they should give you a list of the hazards, how to use (PPE) and Signs/symptoms of exposure. Isocyanate poisoning can be fatal and has long lasting health consequences. Take care of yourselves for the sake of your loved ones as well as yourself. Being a do it your-selfer is meant to be fun and gain a sense of accomplishment. Let's all be around to enjoy our SeaCrafts and share them with the future generation
Greg is right!!! Spraying Awlgrip is NOT for the unprepared!
We had a customer at West Marine who sprayed Awlgrip and thought the protection was for the "Pros" who had repeated exposure. He sprayed in the afternoon and died at his dinner table that night from the poisoning he had given to himself. These finishes are great products, but if you don't want to spend the money on the safety equipment and the time learnign HOW to do it safely, do your family a favor and get a PRO to do it.
Getting home is more important than getting there! Plan accordingly! |
Heard something similar happened to a welder that didn't remove some type of paint, He just "burned" through it. Died 2 days later. Galvanized coating can be nasty also.
" I'm the one thats got to die when its time for me to die; so let me live my life, the way I want to". J. M. Hendrix |
The reason professionals charge so much to spray urethanes etc, is not only due to overhead but also for worker's comp., proper training, equipment and to ensure a quality finish. Always check out the MSDS for all materials you work with. Breathing glass from fairing causes silicosis which is far worse than asbestosis (exposure to asbestos). Both lead to Pulmonary Fibrosis or scarring in the lungs. Lung tissue is soft and moist. Scar tissue is hard and cannot hold moisture. My Grandfather died of Pulmonary Fibrosis, his lungs would bleed and were full of holes because the scar tissue couldn't expand and would crack. Its a sad thing to see someone gasping for air just from walking up a few steps. He was in his mid-70's. Be sure to wear a HEPA filter when grinding, especially glass. Galvanize poisoning can be fatal as well. I work in the HVAC industry, Sheet Metal and galvanize poisoning can occur from grinding as well as welding. If you feel sick after grinding/welding galvanize drink some milk as the calcium will bind the zinc in the galvanize and seek medical treatment from an Emergency Room. If you are having difficulty breathing make sure to call 911 and activate EMS. I used to be an Emergency Medical Technician years before getting into construction. Breathing fumes from "cold" galvanize trade name ZRC can also cause galvanize poisoning. You need to wear special protective gloves when brushing or spray bombing cold galvanize and be in a WELL ventilated area. BE SURE TO GET THE MSDS FROM YOUR DISTRIBUTOR AND READ IT FOR YOUR SAKE AND THE SAKE OF YOUR LOVED ONES. Improper disposal can lead to exposure of your family, children and pets are especially vulnerable and can suffer fatal consequences. Don't mean to beat this to death, just want everyone to enjoy the hobby. SAFETY FIRST. GOD Bless and take care all, Greg
