You will need several roller covers, probably a dozen and probably 2 rollers, unless you step on and break both of them, then you would need 3
![]() I used the MarineEpoxy from beateau for a variety of reasons, but one was it has no amine blush, like west system does. With west and others you should wait for each layer to harden, than clean the blush, then lay the next layer. You probably shouldn't hot coat, but check with the manufactures tech support, not me ![]() Not all epoxies blush but I know for fact/experience west does/can, and MOS and the the MarineEpoxy from beateau hasn't when I used it. You might want to check that out. Those are the only ones I have used. Also, some of the mat has a very thin styrine coating on it which makes it a pita to wet out with epoxy, but helps with polyglass. It doesn't hurt anything to use, but believe me, you can tell the difference if you have used both. I know I sound like I am working for Beateau, but their products are specifically geared for epoxy, and they know what their talking about. |
Go to Walgreens and buy 3 boxes latex gloves for $10. Buy your suits by the box if you can find them. Ones without hood are best. Cut strips where your pockets are if you are someone that tends to put stuff in pants pockets. Vinegar if using epoxy to clean up, isopropyl alcohol if you can get your hands on a couple gallons also helps. I am going on 12 gallons of epoxy - transom, all hatches, all bulkheads and most of the bow in a Sceptre. Latex gloves are cheap but go fast when working with the resins. Also different sizes of plastic pails to mix the epoxy in.
![]() Quote:
Otto And yes, I still believe in the four boat theory... |
Good advice so far. I would epoxy one layer of biaxial on the old skin first and then with your core already pre made and ready next cabosil that to the still hot biaxial/cabosil on the old skin. Clamp that sucker in place so the cabosil gets squeezed out around the edges of core. I like 2x4's thru bolted into the transom then fillet all the voids around the core were it comes in contact with the hull. Let this all set up and then remove the clamps and start laying up the inside. I would use use biaxial and make the inner glass approx 1/4-3/8 inch thick. As far as how to work with large pieces of glass I usually cut it so it will drape over the transom and kinda hold itself up. Anyway you go about it it's still gonna be messy. I like to use OB sleeve (fingerless) with 2 latex gloves over my hands as that will keep the epoxy off your arms.
Be careful when you clamp/tie stuff down, that if epoxy gets on any of the clamps or through-bolts, you will learn exactly how strong epoxy is. This time, I put contact paper on the outer skin (had some laying around), and it was nice to not have to worry about spills/etc. I just peeled it of, and everything came off fine. Expoxy will soak through some of the masking tape that is out there, and you have to grind it back off.
This thread has been incredible!
I still need to check to make sure the mat does not have styrine. Otto - won't be ready for the job this weekend, so you're safe ... but hopefully by next weekend we'll have all the material & be ready. Vinegar is a good idea ... Costco sells by the gallon. Disposable suits is also good & cheap. Already picked up 100 latex/powdered gloves And I have plenty of contact paper ... I like the idea of easy cleanup. Strict - OB sleeve? I like the idea ... can I use the plastic bags newspapers come in? How did you protect the thru-bolts from getting resin on them & sticking? We've heard of the technique of making huge clothespin type clamps & using about 6 to slide over the transom to push it all together. Using 3/4 ply approx 12" wide & long enough to reach the transom bottom & then notching out the expected thickness of Coosa & fiberglass layers. If it doesn't work, want to be prepared for the thru-bolt method. Our total planned layer of construction is: on skin, 1.5 oz mat, 2 layers 1708, 1.5oz mat on Coosa, Coosa Board (clamp & let all set up), then 1.5 oz mat on inside Coosa, 4 layers of 1708. Let set up. Hopefully that's enough to beef up for twin engines. (basic layer construction recommended by Hermco) But he didn't provide a video of the "how to"... so all your tips have been tremedous and I really appreciate your taking the time to post & share. Thank you.
SeaCraft:1966 19' Bowrider & 1962 21' Raceboat |
I would find someone with expertise in clamping the coosa, and do what they did. I came close to using coosa, but went with plywood on the last one. I think that stuff has more flex to it when you clamp then plywood. Also, I don't think it has the compression strength that plywood does. I got away with clamps on the top, boards through the bracket holes, and then a bizaare seriese of bolts and boards through the drain plug. I don't know, but my guess is you will need a little more clamping contact area with the coosa.
I used a layer of 1708 then Coosa. Then two layers of 1708 and then extra tabs of 1708 in all corners. A layer of woven roven will be applied over all this. Plus I added some additional knees in the bottom made out of the Coosa material.
When I removed the old plywood transom. There was only a layer of woven roven, the plywood glassed directly to the skin. |
Sorry Carla OB is short for Obstetrics. I can send you some if you PM me with your mailing address. It would be easier then trying to use plastic bags. The bolts should pound out with a hammer and punch. You can coat them with wax if you want but I have never had a problem removing the bolts. The more I see that 21 hull the more I like it.
![]() strick
I've sent of an inquiry on clamping Coosa & hopefully will get a reply.
Stick - I thought those sleeves might have something to do with your "paying" profession. The disposable suites have sleeves, so I should be fine...thank you for offering. Standing next to the 21, she is impressive & the sheer lines awesome ... you should have one! ![]()
