Old 02-05-2008, 01:07 PM
Ken70 Ken70 is offline
Default Re: 1981 project 23
I don't think I would want a bracket. It would add a few feet that I would have to pay for at the dock. I think the bracket would increase the weight by moving it further from the center of the boat. Maybe the foam floatation in the bracket offsets the weight.
Do you think $4500 would get the boat refinished?
Old 02-05-2008, 01:27 PM
Ken-In this market, you will get the most work for your dollar. The $4500 would be the price area for a transom rebuild from what has been quoted over the past 6 years or so. I have seen a bunch of 23SC's with twin 2.5 block Mercs (close to 900lbs.)without a bracket. Go for it on the Verado!
Old 02-05-2008, 01:34 PM
Donnie from Chas. SC (member here) has a 23' w/bracket and Verado.
Old 02-06-2008, 12:37 AM
htillman htillman is offline
Do a bracket. If you replace the transom go with a bracket no matter what motor you go with. My next project will be with a bracket and from what I read that is the way to go with a 23.
Old 02-06-2008, 12:45 AM
Trayder Trayder is offline
Velvet Jones
no, for $4,500 you will not get that boat refurbished, I do not think it comes with anything, console, rigging, etc. it is just a hull on a trailer.
There is not foam in the bracket it is an air chamber and if you buy the correct one it will offset the weight of the engine at rest but more importantly it sets the engine back into the clean water behind the transom and it gives you more deck space.
Old 02-06-2008, 09:15 PM
The guy I spoke to yesterday said it would cost 40k to restore. When I build my new shop maybe I will take on a project like this myself.
Old 02-07-2008, 07:08 PM
natchalkley natchalkley is offline
ken
i went to look at the same boat yesterday for a friend. the hull was good looking but there is a lot of stuff to do on that boat. one thing that jumped out at me was a crack that extends about 1/3 the width of the notch in the transome . he said that the deck was solid, but I noticed that while there weren't super soft in any one area, they did seem to flex almost all over the boat.
I am in the process of doing a '73 23cc. I am doing it all myself except for the motor setup, so my cost would be a lot different than having someone else do it.
If you can do the work, then I think that you could get the boat in the water and running for ~5k + cost of the engine. that includes builing a console/doghouse, new transom, re-coring the hatches and any kind of electrical work. to have someone else do it( just to do the stuff above) ~10-12k +motor. for a full restoration i would agree with the 40k estimate.
Capt. Nat Chalkley
Get the Net Charters
http://www.gtncharters.com
http://www.getthenetcharters.blogspot.com
Old 03-11-2008, 07:04 PM
KenB KenB is offline
So anyway I bought this project. My plan is to close the transom and bracket, replace the tank (and move it back a little) so I can build a doghouse with potty action, redo the decks, fill the holes in the gunnels, and generally try not to drive myself crazy or broke.
Ryan, the guy I bought it from, is a pretty good guy, and the hull is is good shape.
Obviously, I will be posting on here as soon as I get started. In the mean time I have to finish a tolman skiff, which is about a month away...
Old 03-11-2008, 07:05 PM
Oh I will probably do a suzi 300 for power, unless honda releases a 300. In which case I will think about that one.
Old 03-11-2008, 07:40 PM
I hope so!!! That's what I want!! Sure would like to see some perf. #'s
