My boat is a 1975 sf. I have the glassed over 2x4 as a center stringer. I was suprised to find that it was dry at the transom. I didn't cut up the floor or fuel tank bottom so I'm not sure about the rest of it. I'm really not sure about replacing it if its wet. I would think that even if it is a little wet, you would still have the glass for strength. On the other hand, you have the whole thing exposed, so it would not be that difficult to replace.
so much for saving the transom. Glad I did this now.
![]() port side ![]() another close up ![]() Looks like it is coming apart for me, hopefully will be able to save it and use as a template. I had to stop and pick up the Kid-o so it looks pretty sloppy right now, should be able to get it out, cleanup and straighten some cuts today.
SkipJake 1972 20 S.F , merc 97 150 offshore |
anyone else seen something like this. I guess it was a patch, atleast I think I finally found my leak.
![]() Quote:
thanks for the reply, that makes sense, I think. My transom is soaked and it hasnt seen water in 3 months. I was hoping to baby it out to use as a template, but am about to give up on this. Not a very good pic but the entire port side is mush.
![]() Hard to get much done with only an hour or two a day. I think I am about to "call in dead", and get some work done.
finally removed first sheet of plywood, I guess it needed to come out!!!!?????
![]() heres some scrap should go good in the flowerbed ![]() shot of transom now. ![]()
So, what now. the wood seems as if it is molded into the glass and won't come out quietly or peacefully. Would it just be easier and save time by cutting the entire outer skin and starting over.
I could use some help from the Gods here, if any want to weigh in.
