we tapped around on the hull and transom sounded good. all same tones even in the flexing area but the drain on the other side does not flex.also if you stick finger in drain port it has a little movement. if its flexing must be rot right???also i know rotten wood cant be good... and should be replaced but what can happen if not replaced??
