Old 04-16-2008, 08:20 PM
Dubdlee Dubdlee is offline
Default Re: 1984 18' CC
So just got back from checking it out in person and turns out it's an 83' boat with an 84' yamaha 115 that starts right up, although there is a chip of one of the fins on the lower unit (about an inch or so in diameter). The transom is in good condition, hull is in good condition and the deck is in good shape. Just one spot behind the rear seat next the the rear baitwell that might be a little soft. Trailer in good condition, new lights just need some tires. So, after all that said gonna off 3500, see what he says.
Old 04-18-2008, 04:29 PM
Sounds like a good boat at a good price....good luck
Old 04-22-2008, 05:36 PM
Runco Runco is offline
Did you get the boat?
Old 04-22-2008, 05:55 PM
Mark Mark is offline
The forward "baitwell" doesn't drain in ANY of them, that's why mine got re-routed back through a macerator. Whether it be an 18' or 20', when you stand close enough to pull the drain plug, the drain is below sea level. That 18' you're looking at doesn't have anything wrong in that department, it's a normal one [img]/forum/images/graemlins/tongue.gif[/img]
If the boat is otherwise in decent shape and the engine runs well, $4100 is priced pretty well actually. If that's the model of boat you want, that price shouldn't be an obstacle.
