Old 05-31-2008, 12:19 AM
abl1111 abl1111 is offline
Default Re: Thru transom scuppers conversion from thru flo
Aside from the Criss Cross idea; when you convert from thru floor scupper to thru transom, you gain a few vertical inches as to where the scupper exits the transom - right ?
But, you still need a product like the Rabuds or similar ?
I wish I had done this when I re-did my transom, but I had so much work on my plate, I let it go. Is it a be'atch of a job when all is together ? Again, I have a 23' Tsunami w/ an I/O - it's a little different.
There just is nothing good about the thru floor scuppers; it's to small to drain water quickly, it keeps the floor wet when weight is in the corner, and the brass tubes need replacing very so often.
I want 'em gone. But, only if it is a benefit to do so. Has anyone done a 23' ?
