Old 07-31-2008, 06:15 PM
blunas2188 blunas2188 is offline
Default Re: Quick Question: 23' SF Inboard
Putting in a 260 horse diesel volvo. We are currently waiting for the technician to come for sea trials, so the prop is not for certain yet. But as of now we are swinging a 17'' wheel. However, this could easily change depending on our results next week. When you say ball scuppers, what do you mean and where could I invest in some?
Old 07-31-2008, 07:45 PM
paragod paragod is offline
So u have a inboard outboard not a inboard ? If its a true inboard I would like to see it luv them !
www.texallaluminum.com
Old 07-31-2008, 08:50 PM
Dilligaf Dilligaf is offline
the drain holes go thru the hull??? i thought ball scuppers wouldnt work on the bottom of the boat>?
Old 07-31-2008, 09:17 PM
It is a straight inboard and ill try and get some pics up. But yes, the holes do go right through the hull. This is normal, right?
Old 07-31-2008, 09:26 PM
Yes, it's normal. Ball scuppers will not work with the thru-hull deck drains. But yes, you can put a standard 1" rubber drain plug in the hole from the deck side. If you have the spray deflectors on the hull, you can even put the plugs in from the outside.
Fr. Frank says:
Currently without a SeaCraft
