Old 10-25-2008, 09:45 PM
GradySailfish GradySailfish is offline
Default Re: Fairig problem
I don't think this is a temperature issue, as even with those temps the mix should have cured. I think you may have gotten your ratios off and therefore the epoxy won't cure.
Quickfair is great stuff, but expensive. For minor fairing you can't beat Evercoats polyester fairing compounds. I know its not Marine or epoxy but I was turned on to it by one of the best local fiberglass/retoration shops on Long Island. I have no complaints other then a very fast working time in hot weather.
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
Old 10-26-2008, 07:11 AM
Try putting a heater in the boat to 'warm' things up or try a hair dryer on a section... see if that helps.
Old 10-26-2008, 03:55 PM
Did you make sure you are using the right pumps? there 2 different sets for the sizes. Mix another small batch without the powder and put it somewhere warm and see if it flashes off.
36' Yellowfin
1972 20' seacraft 140 suzuki
