Old 11-26-2008, 01:30 AM
Default Re: Leaks !!
On my 18 the forward fishbox thru hull was loose and leaked only when loaded or when somebody was up there, drove me crazy. Second idea to isolate, put plugs in the outside of the hull and the inside and see if you still get water. OR completely dry out the bilge, have the bilge access open and put the boat in the water, you will see where its running from - either one side or the other or from the bow, just an idea.
You have to isolate and eliminate - kinda like- go back to where you took your pants off to find the truck key
Old 11-26-2008, 03:25 PM
Texascoastalfish Texascoastalfish is offline
Thanks guys for all the input. I have it up in a sling down at Sisters dock in Jamaica Beach. Ill try all your suggestions, and hopefully isolate it. Thanks again !! Tight lines !!
