Old 04-28-2009, 03:15 PM
Default Re: Tramson project
Whats a tramson?
Come on Don, SeaCraft, Wellcraft, Chris*Craft, whatever... - a Stinger, you know - Miami Vice. I know all of you FL boys wanted one at some point
Kcriptos, I ain't an expert but I think Marine ply is the way to go. Cost, workability, and 30+ year reliability if done right. Do a search for transom repair and you'll find tons of info on materials and methods. Start with Strick's post at the top of this forum. It may even persuade you to sell your C*C Stinger If it looks like more than you want to take on call Hermco and show him your stinger Dude does wonders w/frp.
Good luck.
Old 04-28-2009, 03:22 PM
hermco hermco is offline
Whats a tramson?
In naval architecture, a transom is the surface that forms the stern of a vessel. Transoms may be flat or curved and they may be vertical, raked forward (known as retroussé), or raked aft. The bottom tip of the transom can be approximately on the waterline, in which case the stern of the vessel is referred to as a "transom stern", or the hull can continue so that the centreline is well above the waterline before terminating in a transom, in which case it is referred to as a "counter stern".
On smaller vessels where an outboard motor is the source of propulsion, the motor is usually mounted on the transom, and held in place either by clamps or metal bolts that go through the transom. In this arrangement, all the power of the motor is transmitted via the transom to the rest of the vessel's structure, making it a very important part of the vessel's construction.
Old 04-28-2009, 11:13 PM
kcriptos kcriptos is offline
Thanks McGilli for the advice, I'll start my search for the marine ply for my TRANSOM. Sorry for the misspelling, I'm from PR so I'm a lot better in Spanish, speak a little English tough.
P.S. have any of you heard of Sea Cast??
Old 04-29-2009, 09:21 AM
Don't worry about the spelling we like to have a little fun with obvious finger spelling errors.
Ask something is Spanish and I am sure some of us would really butcher it [img]/forum/images/graemlins/tongue.gif[/img]
Old 04-29-2009, 10:43 AM
Obvious finger spelling error?
Old 04-29-2009, 03:22 PM
No te preocupes, que era en broma. Tu ingles esta perfecto. Buena suerte con el transom.
Old 05-04-2009, 06:56 PM
tito tito is offline
Como dice que dijo?
Old 05-07-2009, 12:10 AM
weekender weekender is offline
before ordering Sea Cast check your PM and also check this stuff out
http://www.nida-core.com/english/nor...nd_transom.htm
Old 04-28-2009, 03:54 PM
What is Miami Vice?
Old 04-28-2009, 07:01 PM
Herm you described a transom.
Now try tramson
