Old 06-04-2009, 08:48 PM
Default Re: New Anchor Bracket
Denny, thanks for posting pics and the advice, too.
Still working on the scuppers let them dry all week and now debating how much wood to chew away and what tool to use. I cleaned the wood up with a 1" brass pipe brush I stuck in a in a drill.
I kind of want to leave the glass holes intact and just fill the existing open wood pores with straight epoxy, followed by a thickened filler/fairing coat on the inside of the holes before inserting the 4200 saturated brass tubes and flaring. I keep thinking I want to seal them up but get hung up on that because then the wash-down drainage becomes an issue.
Old 06-05-2009, 12:18 AM
For tools, if you have a flexible extension for a Dremel tool, they make a metal disk coated w/abrasive that will just barely fit thru the hole and it'll chew the wood away pretty easily, especially if there is much rot. Sounds like the wood in yours is in pretty good shape; mine had large chunks missing on one side, and initial fill didn't work . . it just leaked out thru the gaps! If you hit it with some alcohol, the wood should dry out pretty quickly in that California climate! Check the post I did a couple years ago on making up a cored plug so you can just fill the whole thing with thickened epoxy. I ended up with a soft wood core for a pilot hole that makes it easy to redrill for the brass tube (provided you have a 1" dia. metal cutting bit!
I wouldn't seal the scuppers up for a couple of reasons:
1. If you ever take a big wave over the stern you'll wish you had them! You want to get that water out quickly before another wave hits and if you can get on plane, they'll suck out a lot of water real fast. Also with your light motor, your boat should be easily self bailing at rest.
2. Like you say, they come in real handy when you wash down the deck! If you can wash off fish blood before it dries, it's a whole lot easier to clean up.
3. My scuppers lasted about 25 years after initial replacement, and I didn't do anything then but seal them with Life Caulk. Now that they're all sealed up w/epoxy, they should last forever and shouldn't leak into the hull, even if the brass tubes rot out!
Old 06-05-2009, 01:41 AM
seafari25 seafari25 is offline
Location: Eastern Canada...Wallace, Nova Scotia every chance I get
Looking good Denny!
That's the way to go with the anchor. I'll be looking in to doing that down the road.
...and I agree with not filling in the scuppers. Didn't you read my post on the 25 resto thread Gillie? I've never seen rain like that before and the little bit of water that followed the ladies to the cabin wasn't enough to kick my pump in. Also If you ever dock your boat for extended periods of time without full cover, It's nice to know that you're not relying on a pump.
Old 06-05-2009, 05:28 PM
fdheld34 fdheld34 is offline
Wow Denny..talk about some engineering underside...looks like you could pull an oil tanker with your anchor roller!!!!
-FRED
Old 06-05-2009, 08:44 PM
Thanks again, guys. I'll start another scupper thread to redirect this one back to Denny's anchor roller.
