Old 07-18-2009, 02:08 PM
Default Re: 77 Master Angler rebuild
Did some researh and found a product called Marine safty Strip sold at West Marine.
http://www.dumondchemicals.com/html/...ons.htm#marine
Says that it will take off bottom paint down to the gel coat and not harm it.
Anyone try this on their boat?
Going to buy a quart and try it, the worst that can happen is the I throw another $20 inb the ocean (cheap)
Old 07-18-2009, 06:16 PM
I have not tried that one. However every stripper I tried did not budge the bottom paint.
Let us know if it works.
Old 07-19-2009, 09:57 AM
red20 red20 is offline
I used a soybean based stripper that did a good job on removing bottom paint. It took a long time, messy and at the end I still had to wet sand to get all the paint off. In the end I did compound/wax and it came out OK. Just a ton of work.
Old 07-19-2009, 12:17 PM
A ton of work what would one expect ....It's a boat ....lots of work lots of money.... but it puts a smile on your face
Old 07-20-2009, 07:18 PM
Removed this today
Old 07-21-2009, 03:52 AM
No Master Angler should have that piece of crap on it - nice job
Old 07-25-2009, 04:01 PM
I bought a qt of the stripper and applied it to the boat. After 3 hrs I went out and it seems like it is doing a decent job. It does look like I will have to do a 2nd coat and I plan on buying a gal size next time.
what I think is helping is that the person that did the bottom paint did a crappy job and did not sand the bottom 1st or do a barrier coat so it makes it easier to take off.
I think it's quicker and easier than sanding the bottom. Even if I do have to sand etc... it looks like I will save some time and effort.
Old 07-27-2009, 04:38 PM
He's were I'm at with the removal fo the bottom paint.
I brushed on the stripper and waited overnite to remove.
I used a pressure cleaner to help in the removal.
I did not expect a miricle but it worked out ok for the 12 dollars I spend on the West Marine brand. I plan to get another qt and re-apply and pressure clean it again.
I did have better results in the bow area but the back 1/2 still needs some additional elbow grease.
Again not bad results
